https://limaohio.craigslist.org/cto/...504419232.html
1995 Ford F-150 4x4 5.8 351w
Truck runs and drives and stops perfectly fine. Shifts into all gears and does not slip. Does not burn oil. Truck runs really well for the mileage. I swapped it to a manual transfer case. The 4x4 works perfectly. Truck has some rust but not bad for the year. Is a Centurion package or addition, whichever you'd like to call it. You will not find a half ton obs crew cab unless it is a Centurion, so they are a little hard to find. I have never had a problem with the truck. Has a new water pump
Newer ball joints
Newer brakes
New o2 sensor
Fresh tune up in November
Smog pump bypass
5% tint in rear 20% in front installed this past summer
Has 40/20/40 seats in front and rear so it is vary convenient and comfortable.
Has clean title
(Does not currently have the brush guard anymore)
Any questions please text or call if needed and I will do my best to get back with you. Not looking for trades at this time. Thank you
Do not need help selling
Cash talks and nothing else
