+ Reply to Thread
Results 1 to 11 of 11
Thread: Estimated value 93 C350
  1. #1
    Junior Member New User
    Join Date
    Jan 2018
    Location
    The swamp
    Posts
    4
    Default Estimated value 93 C350
    I've been looking at centurions for about a year now. I love the 8th and 9th generation of the F series. This paired with a love for broncos seem to go hand in hand.
    I ran across this 93 C350 with a 7.3 sitting up locally. I've never seen one but I mentioned it to a family friend and he so happened to know where one had been sitting for 4-5 years.
    Any ways, I haven't talked to anyone yet but I was hoping I could get some opinions, problem areas to look at, and an estimated value on this vehicle.
    Any help would be great.
  2. #2
    Junior Member Curious vintageracer's Avatar
    Join Date
    Nov 2011
    Location
    Nashville, Tennessee
    Posts
    28
    Default Re: Estimated value 93 C350
    Looks like it's "sittin" cause a LOT parts are missing. IDI diesel is OK HOWEVER who knows if it will run or not.
    As is always the case the "Price" needs to match the "Condition".
    $2K you should be safe!
    Mike
    "Drive Fast, Turn Heads, Break Hearts"!
    Original Owner 1995 Centurion F350 Extended Crew Cab Pickup
    1993 C150 Black Centurion Bronco (F150 Ext Cab Build)
  3. #3
    Join Date
    Jan 2018
    Location
    The swamp
    Posts
    4
    Thanks vintageracer,
    Its solid with no body work or rusted out areas on the exterior (still need to check the floors). This truck has been in the south so Im not too worried about things dusting out from salt. The only thing that worries me is the sun roof and getting a camper shell for the rear. Looks like the front seats are in the interior and the 2nd row is there too.
    Im not a diesel mech but Id like to upgrade to a turbod 7.3 so maybe that engine not running is ok for now.
  4. #4
    Pimpin' ain't easy Committed Shift's Avatar
    Join Date
    Aug 2005
    Location
    Arizona
    Posts
    178
    I'd like to see the roof. Those stupid chrome fender trim things are probably hiding rust as well. I would assume the motor to be a boat anchor. Free would be a good starting point.
    My Rides:
    1993 C-350 6" lift, 35's, 460, -- Divorce forced sale 10/2010
    1953 Ford F-100 -- sitting on '98 Ford Explorer 5.0 chassis
    1974 Ford F-250 Crewcab 460/4-speed --- Filling the bronco void -- Awaiting modern drivetrain swap
    1965 Lincoln Continental Convertible -- Full custom
    2011 Maserati Gran Turismo S
    2014 Lincoln MKZ
    2003 Lincoln LS
    Moved to AZ in 2013
  5. #5
    Join Date
    Jan 2018
    Location
    The swamp
    Posts
    4
    Quote Originally Posted by Shift View Post
    Here you go.
  6. #6
    Senior Member Sucked In 1985 Bronco's Avatar
    Join Date
    Oct 2015
    Location
    MN
    Posts
    299
    I've never seen one with a sunroof before, how much do you want to bet that it leaks? I'd probably offer 2K or less
    1985 Ford Bronco: No engine right now
    1995 Ford Centurion C150: 351W, E40D, 4x4
  7. #7
    Join Date
    Jan 2018
    Location
    The swamp
    Posts
    4
    Quote Originally Posted by 1985 Bronco View Post
    The tentative plan would be to patch that up. I have a sunroof on my current vehicle and have decided i don't need one.
  8. #8
    Join Date
    Jan 2017
    Location
    Illinois
    Posts
    516
    $1500 to $2500 is about what it is worth. Offer $1500 or less and go up if you have to.
    On these sort of trucks, it is sort of what someone is willing to pay.
    However much money you are planing on spending to fix it up, double it.
    1995 C-350 4x4 7.3 Powerstroke 233,000
    1997 F-250 Powerstroke CC short bed 4x4 7.3 w/ dana 60 swap, stage 1 injectors 294,000
    1997 F-250 Powerstroke CC short bed converted to 4x4 & dually PMF RSK & dana 60 swap 355,000 Over 600rwhp
    1994.5 F-350 Powerstroke Centurion CC dually 4x4 7.3 5 speed 389,000
    2017 Mustang GT 5.0 auto 8,500
  9. #9
    Join Date
    Oct 2007
    Location
    Wroxeter Ontario
    Posts
    496
    Quote Originally Posted by obspsd View Post
    this exactly what I would have said if I would have thought of it first. I got my 90 C350 diesel for $1000 Canadian but it needs complete resto. but it ran and drove (not well)
    you might be looking at a second engien in there as Centurion usually turboed theirs. that roof looks a little scary but you can put another crewcab roof panel in there when the splice gets worked on.
  10. #10
    Join Date
    Aug 2005
    Location
    Arizona
    Posts
    178
    Free.
    It needs a full restoration. A full restoration costs $30k. You could probably get it down to $20k of you do most of the work yourself. Keep in mind you will have a $10k truck when finished with the restoration.
    My Rides:
    2014 Lincoln MKZ
    2003 Lincoln LS
    Moved to AZ in 2013
  11. #11
    Member Excited ShadeTreeBronco's Avatar
    Join Date
    Sep 2009
    Location
    Dover,Delaware
    Posts
    37
    Unless you can get it real cheap, you probably are better off paying more for one in better condition. How many miles are on it? If it has done any towing, the tranny is probably on its way out. That IDI is a good strong motor if it runs. Nineteen ninety three was the first year for the optional dealer installed Banks turbo kit. They are hard to kill if they are taken care of. With the intake breather missing and collecting dirt I would expect the motor to be junk. I would bet that it would almost get 20mpg if it did run. The axles are tough as nails, but the front axle has ball joints that might need to be replaced if the miles are high. If it has auto locking hubs, expect one of them to go bad and leave you stuck in the mud. A bronco cap shouldn't be too hard to come by and I believe Jeff's Bronco Graveyard still has a complete soft top available. Start looking for a crew cab donor truck for a roof and other parts to use. It looks like something I would buy, I would just fix the broken stuff and drive it. LOL
    I love all things Ford !
    91 C350 4x4 460 35" tires no lift
    91 F350 4x4 crew cab (Sold)
    93 F350 4x4 stake body dump 8' Meyers Plow
    87 F450 Superduty stake body (needs bed)
    79 Bronco 2 door 6" lift 35" tires ( needs main brgs.)
    92 Ranger extended cab 3.0 5spd
    2000 Ranger extended cab 4cyl 5spd
    2001 Lincoln Navigator
    76 Granada 351W Edelbrock heads intake cam 650 dbl pumper
    76 Granada 302 (parts car)
    69 Mustang 200 I6 (next project)
    86 CJ-7 (302 swap in progress)
+ Reply to Thread
