Results 1 to 6 of 6
Thread: Extended Centurion Trucks
    May 2016
    Michigan
    11
    Default Extended Centurion Trucks
    For those of you who own trucks converted by Centurion with the rear of a Super Cab grafted onto the rear of a Crew Cab, particularly with the rear seat that converts into a bed; did the convert-a-bed occupy both the 2nd and 3rd rows in both the rear of the Crew Cab and the added on Super Cab and the truck was only able to seat 5 or 6; or was their still a seat in the Super Cab and the truck could still seat 8-9 people even with the convert-a-bed rear seat?
    In other words, was the truck still able to seat 8-9 with the extended Crew Cab and the convert-a-bed rear seat; or did you have to go to the cab where 2 more doors and the extra length were grafted into the center of the Crew Cab in order to be able to have the convert-a-bed and still be able to seat up to 8-9 people?
    May 2016
    Michigan
    11
    Default Re: Extended Centurion Trucks
    What I originally intended on asking is if you wanted to be able to sleep 8-9 people with the convert-a-bed seat, were you able to have this seating arrangement with the extended crew cab like the ones pictured below?
    Or the 6-door like the one pictured below?
    Sleep? 8 people, no.
    The configurations i have seen have been one seat in the back that folds out like a bed, but doesn't cover the whole back of the truck.
    The other was a normal second row and a 3rd jump seat style.
    A door has always been a 3rd bench seat.
    You would have to do some custom work to make it all bed back there. Still you need to think of it as a crew cab with extra leg room an that is about it.
    this thing should have been called a supercrew!
    May 2016
    Michigan
    11
    Sorry, I meant to ask seat 8-9 people; not sleep 8-9 people.
    My mistake.
    It sure can, it is just the configuration you find.
    There is at least 3 seat belts up front.
    3 in the middle
    and 2 or 3 depending on the back row style.
