Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 42
Thread: C350 Hydroboost Conversion
  1. #21
    1,243
    Default Re: C350 Hydroboost Conversion
    AWWWWWYEAHHHH!!! We have some brakes now!! Got everything on today and the brakes work very well. Kept my original pedal assembly...........
  2. #22
    Very cool. Can't wait to hear more after you tow and get some miles on it.
  3. #23
    Senior Member Sucked In BigOldBlueC350's Avatar
    239 & 561
    265
    we need pix !!
  4. #24
    1,243
Size:  101.7 KBName:  boostain2.jpg
Size:  103.7 KBName:  boostain3.jpg
Size:  93.0 KBHopefully pulling the Bronco Hauler and '73 down to Uwharrie on the 21st to do some trail maintenance with the Carolina Bronco Folks. Either that or double redeye like last year and pull the 20ft lowboy. But on to some pickchas!!
    The lines worked perfect using the early '97 version. I bought the dual return pump from Rock Auto with built in "magnafine" filter. I was hitting up advance auto for the remaining stuff I needed like power steering fluid ($12.66/gal) worm gear hose clamps, and 3/8" hose and ran across a hose kit for mounting a remote transmission cooler that came with 4.5 ft of hose suitable for hydraulic fluid, high pressure and capable of being bent to a 3 inch radius for about $4.
  5. #25
    1,243
    Brakes work well, but pump is noisy!! It seems to be running out of balance also. If I run the RPMs up to about 1500 there is a noticeable vibration that was not there before. Plan take a better look this evening. I used the pulley off of the original pump and removed and reinstalled with the proper tool. Might have to follow up with Rock Auto.
  6. #26
    Iirc the pump pulleys are only good for two removals. They need replacement after that. I think I remember reading that on a slip of paper that came with a motorcraft pump I got from the dealership a few years ago.
  7. #27
    239 & 561
    265
    noisy w. a vibration .... sent it back rockauto !!
    I had the same problem w. the pump I got from them !
  8. #28
    1,243
    Quote Originally Posted by sheepman View Post
    pretty sure that was the one pushed on at the factory.
  9. #29
    1,243
    You got a bad one too, Franko? I was thinking of putting my old pump back on!! Wasn't going to change it and just reseal the reservoir but it looked like it was leaking a little out of the shaft seal and wanted dual returns.
  10. #30
    SW Colorado
    11
    I've been missing out on this thread (???) Anyway, the two Ford pumps are identical except for the different housing with the second nipple. If your original pump was satisfactory, just replace the housing/tank with the two-nipple connection type. E8TC-3A578-AA. I have a brand new one here I'll sell for $20 + shipping. However, there's a reason I have this thing, and it's because the Ford pump isn't very good to start with plus it doesn't operate with enough pressure to properly operate the Hydro-Boost. The pumps used by Ford in new production were suitable for HB use, but they all get rebuilt the same way and you can't find a new HB Ford pump even at the dealership. Secondly, they don't seem to deliver enough flow at peak demand either. All these things are solved by going to the Saginaw PS pump like was used on the E series vans. The HB works better AND the steering just feels so much more consistent regardless of what else is going on. My own recommendation would be to use the stock Ford pump with a Tee in the return line in order to get things working, and then upgrade to a NEW Saginaw pump when the opportunity presents itself. Saginaw pumps are available new, in a new housing, with either of two variations on the double return fittings from Amazon for a little over $100. Unlike the "rebuilt" crap (that can cost even more!), these things actually work.
    The hardest part of the Saginaw pump conversion is getting the factory bracket for the Saginaw pump that fits your motor. You will also have to make a custom hose to go between the pump and the HB since none of the E-series vans came with HB and the Sag pump has a 16mm-1.50 o-ring flare fitting.
    Chris
    '86 F-350, 460, 4-speed, 4WD (I love this truck! ), Hydro-Boost, Redhead, Saginaw
    '96 F-350, 460, 5-speed, 4WD, all stock so far
  11. #31
    1,243
    yeah. considered all that. Got new pump with integral microfine filter and both returns to get thing going with out having to find a Saginaw bracket. steering is fine,
    brakes work fine. original pump was leaking from the shaft seal and the reservoir o-ring and I still would have to find the resivor which was not that easy to source.
  12. #32
    1,243
    Pulled my 28ft enclosed trailer with the '73 in it Sunday. Worked very well. Not only did the truck brakes feel much better, the brake light switch works as soon as you put your foot on the pedal which it did not do before because the pedal pressure was so light. Now I can "rest" my foot on the pedal and you can feel the trailer brakes before the truck brakes. Make sense?
  13. #33
    Yeah, you have the old school pressure activated brake controller.
    I get it, you are outdated. Bwahahahaha
    that is awesome, glad it is working well.
  14. #34
    RedNeck In Montana Sucked In InfoFord's Avatar
    Jun 2003
    Montana
    1,009
    pressure activated brake controllers beat the crap out of G force sensing controllers
    and if all possible get rid of that CII ford pump and go to a Sag pump that CII pump barely handles the duty's of steering without issues let alone any extra load on it
  15. #35
    1,243
Size:  87.2 KBName:  camp.jpg
Size:  170.7 KBCouldn't find a good source for a pressure activated brake controller, Swapped out to a Tekonsha P3 proportional and took out the timed. Made a nice improvement. Pulled the trailer 1200+ miles to Murphy NC and wheeled the new Durham/Tellico with the Carolina Broncos. LOTS of big mountains accents and descents providing all kinds of brake work!! Some of the most intense roads I've pulled. Truck did beyond good. Check out the link if ya want to see some more.
    http://www.cb4x4.com/forums/showthre...ico-Pic-thread
  16. #36
    1,243
    ...so who has some clues on sources for pressure activated brake controllers???
  17. #37
    Quote Originally Posted by Bronco Biff View Post
    I've seen them on old Fords, kind of disappeared in the 80s. had a brake line running to and from................................ new technology isn't always better
  18. #38
    Jan 2010
    Mexico
    Maybe this helps you:
    http://www.brakecontroller.com/MaxBrake.pdf
  19. #39
    1,243
    That is pretty sweet, thanks. We just got back from another trip to the mountains. Ran into some rush hour rush hour slinky stop and go traffic.Brakes worked very well.
  20. #40
    Jan 2019
    United States
    3
    deleted spam
