Results 1 to 14 of 14
Thread: The Roof.....yay...
    Senior Member Committed Raduenz's Avatar
    Jan 2011
    Jordan, MN
    103
    Default The Roof.....yay...
    Well today my wife went back home for thanksgiving so that means I got 10 days to enjoys doing the roof on my centurion. I started sanding out the 1/4 inch of filler. Not all done yet but got most of thick stuff out. Found a couple small holes nothing major. Not really rust holes just holes from im guessing when they welded it they burned through and just left them or never filled them. Heres a couple pics. Ill keep posting pics of my progress. Ive read through just about every roof thread so I got the idea of what Im doing but if anyone has anything they want to add feel free. Im not much of a body man but Im not affraid to try everything once so we'll see how it turns out.
    re-seam sealed the drip rails a few months back.
    everytime I chipped more bondo out just slapped some primer over the bare medal
    the holes in the roof are on each side of just about every rib in the roof
    Jan 2011
    Jordan, MN
    103
    Default Re: The Roof.....yay...
    Woops I sure wish I would have covered up my motorcycle i just washed it 2 days ago! o well
    Jan 2011
    Jordan, MN
    103
    DUST!
    find the self tapper punched through my roof..I wonder if thats been like that since 1992
    what a messy project
    Jan 2011
    Jordan, MN
    103
    Last picture. I got some more sanding to do but Im done for the night.
    looks good so far.
    That is the messy part. Too bad there isn't really any other way to do it.
    Looks great though.
    Feb 2006
    indiana
    27
    Don't know if you have heard of this stuff but they make a metal filler now. It's called USC All Metal Filler. It's like in the old days where they used lead for body filler. Haven't ever used it but have heard it works very well. If I had a roof repair like that especially with the weld holes I think I would try that stuff. Don't know who makes it but maybe someone on the list will chime in that has experiance with it. Just sayin.
    frenchy
    frenchy
    66 Bronco Original Factory Roadster 77 BroncoTrail Rig
    I have used that stuff, the worst part about those fillers are they are so hard to work with.
    They are great for a base and building it up where you need it to be, but to finish sand it and paint it, you need a different material.
    Member Serious Bronco-Lover's Avatar
    Oct 2011
    Kansas City
    71
    Don't leave me hang'n. How's it comming with that roof? Mine is a lot worse off, but thinking I am gonna try to fiber glass it when I get to it.
    89 C350 7.3 Banks Turbo, E4, 4.10, and 16.5 x 33's
    Jan 2011
    Jordan, MN
    103
    So this project sucks! I think the worst part about it is sanding it all nice and smooth. but im just about done. So them small holes I just packed some 5 min. steel apoxy in them and let it harden. Then i sanded it smooth you couldnt really tell there was a hole there.
    This is some rust treatment I got. It sprayed on clear and then would turn black as it treated it. That stuff had to sit for 24 hours im not sure if it really works/helped
    This is the first layer of some short strand fiberglass filler. I only did like 3 light layers i didnt go that thick compared to how it was before. the only "thicker" spots was where the roof had kind of a dip so i built it up a little so water wouldnt set in there.
    Jan 2011
    Jordan, MN
    103
    The first two layers of fiberglass filler i was using 40 grit sandpaper then the last coat i went to a 80 grit
    I think i got the fiberglass filler looking pretty good then I used some light weight bodyfiller on top of that to fill all the fiberglass imperfections and my 80 grit scratches.
    I still have a couple small spots to touch up and im going to finish grinding out my gutters so i can re-seam seal them. Then its time for primer and paint
    Idaho, United States
    4,457
    Looking good.
    Oct 2011
    Kansas City
    71
    thanks for doing the pics and walking us thru it. I am eager to see the finished steps of yours and get to mine cause I don't want to drive it in the rain until it is fixed. I also am sporting a good amount of duct tape on the roof and even tho it is a truck, it just isn't dignified enough for such a beautiful deserving girl!
    Senior Member Sucked In 1985 Bronco's Avatar
    Oct 2015
    MN
    299
    Did you ever finish this? It looks really good!
    1985 Ford Bronco: No engine right now
    1995 Ford Centurion C150: 351W, E40D, 4x4
  1. new roof....
    By zakt in forum Roof Repair
    Last Post: 02-26-2015, 06:41 AM
  2. Going to fix my roof
    By trey in forum Roof Repair
    Last Post: 05-31-2011, 08:27 AM
  3. My 89 C-350 roof job
    By wade_hack in forum Roof Repair
    Last Post: 11-09-2010, 12:48 PM
  4. How to fix the roof
    By BJS in forum Roof Repair
    Last Post: 09-26-2005, 10:56 AM
  5. The roof
    By Audra in forum Roof Repair
    Last Post: 08-27-2004, 08:05 AM
