This is a feeler to see how much interest there is for my 96 Centurion FDB Powerstroke 4x4.
I have not Officially put this Four Door Bronco up FOR SALE yet!
Please Private Message me if you want to contact me. Do not post your phone number in this thread asking me to call you, I may miss your post and you'll end up wondering why I haven't called.
I have owned this FDB for the past few years. I purchased it in Sept. of 2007 near Albuquerque, New Mexico. At the time the FDB had 159,000 miles on it and was being sold by it's second owner who bought in 1998 from Rich Ford in Albuquerque as a lease return. The second owner kept it parked under a car port all those years. IIRC this truck has never had a loan against it.*
Today this FDB has 183,500 miles on her and runs great, the engine is in tip top shape. I replaced the E4OD transmission this past spring at 180,600 miles. I also installed a new Triple Disc Billet Torque Converter and custom acculatetor body from Racer X. I also installed a new transmission pan with a drain plug.
Both front and rear a/c work along with heaters. Back window goes up and down with ease. Two rear door windows are getting sluggish. I think they need to be greased, I have this on my to do list. Headliner has a few small sag spots. Wood trim is in very good shape and so Is the center console. Heated and cooled cup holders work great. Drivers power seat works fine in all six ways. Rear seat folds down with ease. Leather is in great shape for it's age and the seats are very comfy still. Front seats have a few stitches coming lose. Ten disc cd changer works too.
Roof is cracking again. I had the roof redone in Dec of 07. Body shop said they would redo it. However, they've been to busy or I've been gone with truck when they could. I think it will be redone soon.
Rebuilt turbo with banks wheel and 1.00 turbine -Oct 07
EBPV delete - Oct 07
Isspro boost, Pyro and Trans gauges - dec 07
3 gauge piller pod - dec 07
New driving lights - fall 07
Straight piped exhaust - Jan 08
New napa fan belt spring 08
Napa vac pump - spring 08
Napa master cylinder - spring 08
New front brake pad - spring 08
New front calipers - spring 08
New inner and outer front wheel bearings - spring 08
New ABS valve - spring 08
Right rear leaf spring bushings - summer 08
Remote start with keyless - dec 07
3" ss downpipe - oct 07
Out rear window seal - summer 08
Lower rear door seal - summer 08
Darkest legal window tint - spring 08
Front and rear diff fluid - spring 09
Front air ride - spring 09
Front shackle bushings - spring 09
New Monroe front shocks - spring 09
New CPS - spring 09
4 new Dunlop Rover A/T tires - spring 10
Local remaned trans - spring 10
Banks transcommand - spring 10
Replaced PCM (true TDE1) - Spring 10
New Racer X triple disc billit TC - spring 10
New custom Racer X accumulator body - spring 10
New trans pan with drain and gasket (motorcraft) spring 10
New Banks stinger plus chip - spring 10
Here are few photos.
I don't have any newer photos yet, I will once she is all cleaned up.
I'm thinking of 13k for this rust free truck.
