Results 1 to 17 of 17
Thread: Motor Rebuild
    Centurion Lover Sucked In Chase Schule's Avatar
    Jan 2009
    Granite Falls Wasington
    373
    Default Motor Rebuild
    So im getting to the point where im going to rebuild my engine soon and the 8th hole has been out and theres probably going to be a slight lip in the cylinder so its gona neew to be bored and id really like to keep it in the 460 area but im thinking 460 bored over 60. let me know what you all think!!
    Senior Member Sucked In nestevec's Avatar
    nebraska
    260
    Default Re: Motor Rebuild
    The bigger the better. There's a guy here in town that has a 460 punched out to a 501 for sale.
    Jan 2009
    373
    oh yea!!
    Jan 2009
    373
    well its time and im gettin a rebuild and doin it right truck is apart only about 9 hours into doin it haha!
    Jan 2009
    373
    Senior Member Sucked In SMOOTH's Avatar
    Apr 2008
    Holly Springs, NC
    787
    Good Luck! Keep the pics coming!
    MoMo
    <img src=http://www.supermotors.net/getfile/780790/fullsize/trucks_wideshot.jpg border=0 alt= />
    88 bronco T-Top, 302 (gt40p heads, comp cam, ford racing headers), AOD, BW-1356, 6 inch suspension lift, 35 procomps
    - waiting for me to finish a 514efi and front/rear 60's.
    92 Centurion 7.3idi, Banks non-wastegated turbo, E4OD, BW 1356, 35 procomps.
    82 E350 Cabriolet "Vanchero" 460/C6/4.11posi
    "Never underestimate the predictability of stupidity."
    - Bullet-tooth Tony and his friend, Desert Eagle .50
    Those are great pics.
    Does it do any good to bore out a speed density motor? Or add a performance cam?
    Aren't you still limited to the factory fuel map?
    Apr 2008
    Holly Springs, NC
    787
    Not that I'm speaking from any type of extreme knowledge, but yes you are limited to the factory fuel map, but you can add somethings and get some performance.
    My 302 in my 2 door was bored, I think, .40 over, got a speed density cam from Comp, GT-40P heads and matching headers. Runs great. I also put larger injectors (I think 19 lbs). It ran rougher with the injectors but I just put a metering block on the idle control for now. Just to carry me over until the new engine.
    MoMo
    Senior Member Committed
    Jun 2010
    Slatington PA
    153
    I bought a mass air pigtail years ago. Four wire hookup and swap two wires for the injector firing order with the 351. Dunno if you could do that to a 460 but its worth looking into.
    Jan 2009
    373
    the factory fuel map can be changed im pretty sure ive got some people that know all about that ready to check it out!
    upgrading... $5 at a time Sucked In
    3,140
    Boy those pics look familiar!
    Can't wait to see the progress.
    Jan 2009
    373
    Jan 2009
    373
    Jan 2009
    373
    we have a parts bronco that was for my brother i toke the front fenders and will put those on and us those to drive around on so i can do some mods to the fenders that were on it and fix some bolts that need to be drill out and stuff!!
    3,613
    Jan 2009
    373
    haha
    Jan 2009
    373
    So my dad thinks i should get out all the wiring and change it from fuel injected to carb, but i'm not sure he wants me to do that so if anything ever brakes out somewhere i can get parts easyer and acctrully fix it but also beacuse when we mod the motor a bit and give it max torque and take the smoke off were not quit sure what its going to do to the computer, beacuse all the vacum and everything has plugins from the wireing. but i dont think i want to! if i can get the smoge off and have the eigine look beast with out to much wireing everywhere that would be great and have the vacum crap pluged in to the harness eliminated without messin with the computer of the truck and all that would be sweet!!
  1. E4OD rebuild
    Last Post: 11-01-2016, 01:12 AM
  2. Rebuild or swap?
    Last Post: 01-16-2012, 11:36 AM
  3. 7.3 oil cooler rebuild
    Last Post: 03-29-2011, 03:15 AM
  4. replace engine or rebuild top end?
    Last Post: 11-18-2009, 11:06 AM
