Results 1 to 6 of 6
Thread: Tires?
    Senior Member Committed
    westville, sc
    121
    Default Tires?
    One more question. Yall will get tired of me before this is over. Anyone have suggestions for good tires for a c350? I looked at pro comps, but don't know anything about the quality. I drive 2-3 times a week around town and will be in the mud occasionally, but not often enough to jump to mud terrains. Any help? Thanks.
    New State to call home? Sucked In Kasprzak's Avatar
    Jul 2005
    Draper, UT 84020
    1,232
    Default Re: Tires?
    The nitto's or toyos you have on it should be great for that. At is At none do that well in the mud. Bridgestone Revo's do pretty well, ASK Audra.
    DREAMS Can only come true if you take some time each day to create them.
    westville, sc
    121
    Default Re: Tires?
    The ones on it now are bf goodrich's and are nice, but are about $250.00 a piece to replace. I was hoping to get buy a little cheaper for a while till I can put some nicer ones on it.
    Pessimisticly Optimistic Sucked In JohnDeStef's Avatar
    May 2005
    SW Florida FourDoorBronco.com Moderator
    2,193
    Default Re: Tires?
    The rim size you have is very important in determining what tire is best.
    Example: I have 16.5s, so I'm very limited in what I can run. My BFG A/Ts suck butt. Belts in the tire have snapped, leaving ridges/bubbles on the sidewalls and consequently trashing the balancing.
    I'm looking at Cooper Discoverer LTs, although their site says this about the tires which I'm not thrilled with... "It is especially suited for light truck drivers seeking solid all-terrain performance and wear, with less emphasis on a ride quietness. Yuck, has anyone run these tires???
    So what rim ya got?
    westville, sc
    121
    Default Re: Tires?
    the tires on it now are 285/75 r16's. HOpe that helps.
    May 2005
    2,193
    Default Re: Tires?
    Well for that size you've got quite a selection.
    If you think the tread could be a little wider.. it *looks* like it could from your avatar... you could go up to a 315/70, it'll help it handle a bit better.
    Here's a handy dandy little site... 1010tires.com w/ tire calculator
    Not all tires made appear with the given sizes, only the ones they sell.
    <TABLE style="BORDER-COLLAPSE: collapse" borderColor=black cellSpacing=0 cellPadding=4 background=images/spacer.gif border=1><TBODY><TR bgColor=#d3d3d3><TD>Stock Tire - 285/75R16 >Search Tires </TD><TD>Tire 1 - 305/70R16 >Search Tires </TD></TR><TR onmouseover="style.backgroundColor='#D3D3D3'; window.status='Section Width: the width of a tire; the width at its widest point from sidewall to sidewall.';" style="BACKGROUND-COLOR: #ffffff" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width=280><TBODY><TR><TD width=100>Section Width:</TD><TD align=right width=80>11.22 in</TD><TD align=right>285 mm</TD></TR></TBODY></TABLE></TD><TD><TABLE width=280><TBODY><TR><TD width=100>Section Width:</TD><TD align=right width=80>12.00 in</TD><TD align=right>305 mm</TD></TR></TBODY></TABLE></TD></TR><TR onmouseover="style.backgroundColor='#D3D3D3'; window.status='Rim Diameter: height of the wheel this tire will fit on';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width=280><TBODY><TR><TD width=100>Rim Diameter:</TD><TD align=right width=80>16 in</TD><TD align=right>406.4 mm</TD></TR></TBODY></TABLE></TD><TD><TABLE width=280><TBODY><TR><TD width=100>Rim Diameter:</TD><TD align=right width=80>16 in</TD><TD align=right>406.4 mm</TD></TR></TBODY></TABLE></TD></TR><TR onmouseover="style.backgroundColor='#D3D3D3'; window.status='Rim Width Range: recommended rim widths that this tire will fit on';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width="100%"><TBODY><TR><TD width=100>Rim Width Range:</TD><TD align=right width=80>7.5 - 9 in</TD></TR></TBODY></TABLE></TD><TD><TABLE width="100%"><TBODY><TR><TD width=100>Rim Width Range:</TD><TD align=right width=80>8 - 9.5 in</TD></TR></TBODY></TABLE></TD></TR><TR onmouseover="style.backgroundColor='#D3D3D3'; window.status='Diameter: overall height of the tire';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width=280><TBODY><TR><TD width=100>Overall Diameter:</TD><TD align=right width=80>32.83 in</TD><TD align=right>833.88 mm</TD></TR></TBODY></TABLE></TD><TD><TABLE width=280><TBODY><TR><TD width=100>Overall Diameter:</TD><TD align=right width=80>32.81 in</TD><TD align=right>833.37 mm</TD></TR></TBODY></TABLE></TD></TR><TR onmouseover="style.backgroundColor='#D3D3D3'; window.status='Sidewall: the height of one tire sidewall';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width=280><TBODY><TR><TD width=100>Sidewall Height:</TD><TD align=right width=80>8.41 in</TD><TD align=right>213.61 mm</TD></TR></TBODY></TABLE></TD><TD><TABLE width=280><TBODY><TR><TD width=100>Sidewall Height:</TD><TD align=right width=80>8.40 in</TD><TD align=right>213.36 mm</TD></TR></TBODY></TABLE></TD></TR><TR onmouseover="style.backgroundColor='#D3D3D3'; window.status='Radius: height from the center of the tire to the outside edge';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width=280><TBODY><TR><TD width=100>Radius:</TD><TD align=right width=80>16.41 in</TD><TD align=right>416.81 mm</TD></TR></TBODY></TABLE></TD><TD><TABLE width=280><TBODY><TR><TD width=100>Radius:</TD><TD align=right width=80>16.40 in</TD><TD align=right>416.56 mm</TD></TR></TBODY></TABLE></TD></TR><TR onmouseover="style.backgroundColor='#D3D3D3'; window.status='Circumference: distance around the outside edge of the tire';" style="BACKGROUND-COLOR: #ffffff" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width=280><TBODY><TR><TD width=100>Circumference:</TD><TD align=right width=80>103.1 in</TD><TD align=right>2618.7 mm</TD></TR></TBODY></TABLE></TD><TD><TABLE width=280><TBODY><TR><TD width=100>Circumference:</TD><TD align=right width=80>103.0 in</TD><TD align=right>2616.2 mm</TD></TR></TBODY></TABLE></TD></TR><TR onmouseover="style.backgroundColor='#D3D3D3'; window.status='Revs per Mile: number of times this size tire rotates when travelling one mile';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE><TBODY><TR><TD width=100>Revs per Mile:</TD><TD align=right width=130>633.5</TD></TR></TBODY></TABLE></TD><TD><TABLE><TBODY><TR><TD width=100>Revs per Mile:</TD><TD align=right width=130>633.9</TD></TR></TBODY></TABLE></TD></TR><TR onmouseover="style.backgroundColor='#D3D3D3'; window.status='Speedometer: speedometer readings when travelling at 60mph / 100km/h';" onmouseout="style.backgroundColor='#FFFFFF'; window.status='';"><TD bgColor=#eeeeee><TABLE width=280><TBODY><TR><TD width=120>Actual Speed:</TD><TD align=right width=80>60 mph</TD><TD align=right>100 km/h</TD></TR></TBODY></TABLE></TD><TD><TABLE width=280><TBODY><TR><TD width=100>Speedometer1:</TD><TD align=right width=80>60.0 mph</TD><TD align=right>100. km/h</TD></TR></TBODY></TABLE></TD></TR><TR onmouseover="style.backgroundColor='#D3D3D3'" style="BACKGROUND-COLOR: #ffffff" onmouseout="style.backgroundColor='#FFFFFF'"><TD bgColor=#eeeeee>Speedometer Difference: -</TD><TD>Speedometer Difference: 0.063% too fast</TD></TR><TR onmouseover="style.backgroundColor='#D3D3D3'" style="BACKGROUND-COLOR: #ffffff" onmouseout="style.backgroundColor='#FFFFFF'"><TD bgColor=#eeeeee>Diameter Difference: -</TD><TD>Diameter Difference: 0.07%</TD></TR><TR><TD vAlign=top bgColor=#eeeeee>BFGoodrich All-Terrain T/AŽ KO
    BFGoodrich Mud Terrain T/A <SUP>KM</SUP>
    Bridgestone Dueler A/T (D695)
    Bridgestone Dueler A/T Revo
    Dunlop Radial Mud Rover
    Dunlop Radial Rover RVXT
    Falken Ziex S/TZ04
    Firestone Destination A/T
    Firestone Destination M/T
    Goodyear Wrangler MT/R
    Goodyear Wrangler SilentArmor
    Kumho Road Venture MT (KL71)
    Michelin LTX A/T2
    Michelin LTX M/S
    Pirelli Scorpion ATR
    Toyo Open Country A/T
    Toyo Open Country G-02 plus
    Toyo Open Country M/T
    Yokohama Geolandar A/T-S
    Yokohama Geolandar H/T-S G051
    Yokohama Geolandar I/T+
    Yokohama Geolandar M/T+
    </TD><TD vAlign=top>BFGoodrich All-Terrain T/AŽ KO
  1. Tires
    By THE BOSS in forum Four Door Bronco, Centurion, Magnum Ect.
    Last Post: 06-12-2009, 10:14 PM
  2. 11.00-16 michelin mud tires $350 a set
    By broncoholic in forum Conversion PARTS for sale.
    Last Post: 10-20-2008, 06:29 PM
  3. how big of tires????
    By 79lariat in forum Four Door Bronco, Centurion, Magnum Ect.
    Last Post: 11-27-2007, 09:45 PM
  4. New tires
    By 79wolf in forum Tech write ups and Installs
    Last Post: 01-16-2006, 11:50 AM
